Just a quick one.
The plate riveted to the underside of my Rocker cover(M20 2.5)
Has come off.
Is this part that important?
I can see more oil perhaps getting sucked through the vent tube, is this a big problem.
I can't see an easy way of refixing it.
Dan.
Rocker cover plate
liquid079
biffer
I refitted mine by drilling the original fixing-points to accept small self-tapping screws.
To make sure the screws wouldn't come loose and fall into the valve-gear i used serrated washers too.
liquid079
I bolted it on in the end. Drilled three holes roght through and used sealing washers so it was air tight.
It'll do until I buy a new cover.
Cheers, Dan.
Cheers, Dan.
