Double and single valve spring on m20
markus_74
Post Mon Jan 22, 2018 11:30 pm
Hello,
Back again to zone and Happy new year friends here.
My e30 325i, has symptoms like one of Cyl loss compression but it is not really only the compression is not perfectly same. Cyl 1 has 150psi and the rest between 140psi.
I have change and rebuilt the engine block with new rings. The big mistake is I'm not replace the wear valve guide and I only install single valve spring that it should be double. Does only install one spring will make lower compression and the symptoms like misfire/one Cyl dead/loss? Thank you. Markus
reggid
Post Tue Jan 23, 2018 7:40 am
no, unless you are reving it so high the valves are bouncing. the ETA engines had the single outer spring
E30 325is with M20B31
