92 325i touring exhaust
Scotty200
Post Sat Aug 05, 2017 3:53 pm
Hi, I've just purchased a race land manifold for my 92 touring 325i which has cats, does this make it a 2 piece system and the manifold only fits a 3 piece system? The manifold is in 3 pieces the two headers and a x pipe, does anybody know if I can get it to fit or am I wasting my time?
Thanks scott
Cloggy Saint
Post Sat Aug 05, 2017 4:40 pm
Cut and weld is the unfortunate answer.
Scotty200
Post Sat Aug 05, 2017 5:12 pm
Thanks for the reply, I was hoping that wasn't the case lol does anybody know if I can run a de cat pipe? At lest then I'm not cutting the exhaust up and make a straight pipe to fit
Cloggy Saint
Post Sat Aug 05, 2017 6:06 pm
The cat can be removed without affecting anything. Are you sure you have a 2 piece exhaust?
Scotty200
Post Sat Aug 05, 2017 11:29 pm
As far as I'm aware I have a 2piece exhaust unless it's been welded up already, I've got the cast manifold, then the down pipe from the manifold to after the cat then from there to the back box? This is what I can see from lying on the floor, I've checked on Real oem and it looks the same as the cat exhaust on there
Scotty200
Post Sat Aug 05, 2017 11:33 pm
https://www.etkbmw.com/bmw/EN/search/se ... CE/18_0170
This is what I see on my 92 touring to make explaining easier
Cloggy Saint
Post Sun Aug 06, 2017 10:20 am
If you really want to fit the manifold with no fuss you could swap to a 3 piece system.
Post Mon Aug 07, 2017 12:15 am
Are you in the UK, and what's the build date of the car and date of first use?
Scotty200
Post Mon Aug 07, 2017 7:39 am
Hi yes I'm in the uk, I'm not sure how I find out the build date? Registration was august 1992,
