Clutch pedal picking up too high
CFS318
Post Sun Jul 16, 2017 4:19 pm
I replaced my clutch including pressure plate & bearing as the pedal was at the top when the clutch engaged & it felt as though there was some slip.
This did not improve with the new unit as the clutch still only engages with the pedal near the top position. I understand that the adjustment is hydraulic and that there is no mechanical adjustment on the pedal.
Can anyone please advise what the problem may be.
The vehicle is a 318i M10 1987 left hand drive.
Post Mon Jul 17, 2017 6:36 pm
I have been told that this could be the slave OR master cylinder, whichever way it is, change both at the same time.
BenHar
Post Mon Jul 17, 2017 7:51 pm
martauto wrote:I have been told that this could be the slave OR
Unlikely. If either is dying the affect is the opposite.
Ben
Post Mon Jul 17, 2017 8:38 pm
Could be wrong slave cylinder holding the clutch release arm out too much
CFS318
Post Wed Jul 19, 2017 7:48 pm
Many thanks to all for the advice.
