Front wheel bearing
chinna
Does anywhere sell the front wheel bearings on there own or is it the hub and bearing only
Sanchez
Front is hub and bearing, rear is just bearing.
chinna
No problem. Just ordered 2 Febi. Hopefully ECP won't feck up and will get them in for tomorrow. Thanks for the quick reply.
Doobit
Have to fitted your bearings yet. I have to replace the font wheel bearings on mine. was it an easy job?
E30 325i Cabriolet Alpinweiß chromie
F12 640d
G11 730d
F12 640d
G11 730d
gromgsxr
When i did mine it was a easy job bearing just pulled off the stub with hand power but i may have got lucky there.
Grzesiek325i
Inner ring can stuck on shaft but bearing splitter it's not expensive tool
Doobit
Thanks guys. I'll try it myself.
F12 640d
G11 730d
F12 640d
G11 730d
TriggerFish
Mine did this - just removed the brake back plate and used a smaller puller to get the inner ring off.Grzesiek325i wrote:Inner ring can stuck on shaft but bearing splitter it's not expensive tool
My local ATS even let me use their torque wrench as I've misplaced my decent one during a house move, and could only get it to 170lb/ft accurately.
Doobit
Thanks guys, so far so good. Needed me and the missus standing on a breaker bar to loosen the axel shaft nut, which was quite romantic. And the brake caliper nuts were a bugger to get undone until the WD-40 soaked in.
F12 640d
G11 730d
F12 640d
G11 730d
aimlessrock
Having an + sized wife really helps in situations like this- armed with a breaker bar there are few bolts that will not yield under such pressure..Doobit wrote:Thanks guys, so far so good. Needed me and the missus standing on a breaker bar to loosen the axel shaft nut, which was quite romantic. And the brake caliper nuts were a bugger to get undone until the WD-40 soaked in.
essential for any resto
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
