how do you remove the Vibration damper once the bolts are out? Mine seems to be stuck, don't want to hit it just yet. Is there another way?
Cheers.
Vibration damper removal
Stevieabz
1987 325i Sport M-Tech 1 - In Absolute Pieces - www.youtube.com/restoreit - For videos on this E30.
1989 325i Touring - Undergoing a much quicker restoration
1985 320i Sedan - Future Project
BMW 1 Series M Coupe - Daily Driver
paultv
no, hit it!!!
Stevieabz
Haha, Just got back from hitting it and can confirm. Yes, hit it.
Cheers.
Stefan on probation
Did it fall through the rusty boot on to the ground?
Stevieabz
I am stripping the engine down so everything else is off. I used a mallet and held on to it
Not an issue in the end
I think the OP is referring to the vibration damper originally fitted to the front end of E30 prop shafts, and SexyLady is thinking about the one in the boot of cabs., but the answer is the same - they are both held in place only by the obvious bolts. The one on the propshaft no longer has a job to do, but the boot one is still required.
