Broken glovebox handle
M3KUK
Post Tue Jun 06, 2017 8:51 pm
Hi, I have managed to break my glovebox handle off and it now won't open. How can I fix it please?
ah
Post Tue Jun 06, 2017 9:12 pm
I had this happen on my second E30,as I recall I pulled the glove box down just obove the latch as much as I could without backing it more and then getting a small flat screw driver and push it in the gap you've made, and then push it up against either side of the latch which should release it,good luck,when you've opened it have a look at Bmwoem parts and you will find the part that's broken can still be bought without buying all the latch and lock.
M3KUK
If I get a new lid can I swap the key barrel over?
mark_i
Post Tue Jun 06, 2017 9:15 pm
sure can... 2 screws and a circlip Mike
ah
Post Tue Jun 06, 2017 9:22 pm
Post Tue Jun 06, 2017 10:12 pm
M3KUK wrote:If I get a new lid can I swap the key barrel over?
Can't see the point of that. Whats wrong with swapping the catch from the 'new' lid into the existing one.
drakesmith
Post Wed Jun 07, 2017 12:04 am
Go under the back of the latch (handle) and push up or down the lock mechanism. It will unlock
M3KUK
Post Wed Jun 07, 2017 7:56 pm
Got it open, the hinge has snapped off, so need a new handle. I will then have to swap the key barrel over to keep the same key.
M3KUK
Post Fri Jun 09, 2017 11:17 am
Cotswold do a repair kit for £21.
