Lock set and ignition..
marvelos
Hi zoners.. Just a quick question want to replace the locks and ignition on my 1987 tech 1 sport, would it be ok to replace with set from a face lift model.. Cheers
ChrisHC
- E30Zone Contributor
You know that with a lock rebuild kit you can rebuild the door locks to fit any key?
marvelos
No I did not know that sir! Sounds like a much more sensible option.. Just get them on line?
ChrisHC
Yes, they are a BMW item so Cotswold would be good. It is a little bit fiddly but satisfying when it works. Effectively it replaces the entire lock.marvelos wrote:No I did not know that sir! Sounds like a much more sensible option.. Just get them on line?
The kit also includes the L shaped alloy piece on the back of the drivers door lock assembly, which is the part that suffers the most wear. Only available as part of the kit.
