In the event that heat and WD40 will not allow me to remove the fittings, does anyone know where the threaded bolts originate on the floor of the folding top compartment that stick up through the two floor mounts of the main hinge: from the drawings it looks as though they are part of a reinforcement section under the compartment on each side...
Has anyone had to trash these fittings and replace?
any guidance would be helpful before I destroy everything!
Paul
