Does this thing just pull off via its clips? Or is there adhesive too? Stripped everything off bar glass to repaint but it seems stubborn, don't want to bust bits. It must be easy as I can't find reference to others asking...
Touring tailgate spoiler removal
Sorry, clips just locate it while the factory adhesive (polyurethane) sets.
Cloggy Saint
Shutthatdoor
Thanks guys for confirming and advice - I guess it's a bond back on job with silicone or mastic when it's time.
Cloggy Saint
Shutthatdoor
Ill be very very careful. Thanks again for the pointersCloggy Saint wrote:Clips are still available from the dealer to correctly locate the spoiler when refitting. Be extremely careful not to put a kink in it as you'll never get it straight again!
I have the BMW instructions for fitting the touring tech II rear spoiler in pdf. form. This is one of 90+ pdf. files that should have made it into the wiki, but a few including this one went astray somewhere between here and Poland.
The instructions include removing the original small spoiler, and reading through them, it looks like only the Tech II is held on by polyurethane adhesive. It suggests the original is fixed with double sided adhesive tape, and is removed simply by twisting it upwards as if it was hinged along the top edge.
If the OP would like a copy of this pdf., please PM me an email address.
Cloggy Saint
Shutthatdoor
Cheers Brian I'll give it a go now, thanks for pursuingBrianmoooore wrote:I have the BMW instructions for fitting the touring tech II rear spoiler in pdf. form. This is one of 90+ pdf. files that should have made it into the wiki, but a few including this one went astray somewhere between here and Poland.
Shutthatdoor
That worked thanks, really stubborn stuffCloggy Saint wrote:Standard spoiler does have a thin strip of tape that sticks to the glass but I would still advise first breaking the seal with a blade.
