Oil for 200K mile M20B25?
acme15
Post Mon Feb 20, 2017 11:09 am
Hi all, just wondering what oil you would recommend for my car. Its a 325i with 195,000 miles on the clock. It is currently running 10W40 semi synthetic, but in its advancing years and bearing in mind the fact that I do drive the car hard at times, I was wondering if I should try a heavier oil?
I'm fairly sure it isn't burning any oil, but it does leak a 'little' as all M20's do, but not too badly all things considered.
Thanks all. :)
Post Mon Feb 20, 2017 2:01 pm
It's not a Ford or a Vauxhall! At 195,000 miles, and assuming its been properly maintained, I'd expect everything, except the exhaust valve guides, still to be within new tolerances.
10W-40 should be fine to continue with, but a full synthetic would be better.
biffer
Post Mon Feb 20, 2017 7:57 pm
opie oils on here used to recommend 5w40 for these cars but recently seem to have been pushing 10w40 instead.
mine seems to thrive on 5w40 full synth.
acme15
Post Wed Feb 22, 2017 12:04 pm
I'll keep using what I'm using then, thanks all.
Conveniently all three of my cars (MX5, Octavia TDI, and the E30) take 10W40 Semi, so I have a large stash of Shell Helix HX7...
