End ring gap too tight
markus_74
Post Fri Jan 13, 2017 12:28 pm
Hello,
I need some advice about end ring gap.
What will happen if top ring compression is too tight.
In my case my engine has 0.1mm end ring gap that I measure from the bottom cylinder wall.
Does it will contact and bend and scuff?
If yes, I will reboring my engine to 0.2mm
Thank you
Markus
M3Pete
Post Fri Jan 13, 2017 2:33 pm
Instead of boring the block, would it not be easier to file the piston rings to the required gap?
markus_74
Post Sat Jan 14, 2017 1:35 am
Does is it recommended to file the end ring?
reggid
Post Sat Jan 14, 2017 4:55 am
markus_74 wrote:Does is it recommended to file the end ring?
yes, nobody ever over bores to suit ring end gap because then what about the piston to bore clearance....
E30 325is with M20B31
Carmo13
Post Sat Jan 14, 2017 11:26 am
Take a look at the bottom of this page.
If you have the time give the whole thread a read, i found it really interesting.
http://www.e30zone.net/modules.php?name ... c&start=50
