Silicon Hoses
aimlessrock
Post Sat Dec 17, 2016 11:59 pm
is there any benefit to using silicon as opposed to oem on the cooling system hoses.?
A couple of mine are looking a little past it... considering replacing the lot with new silicon ones.
Any comments welcome.
E30 320i Convertible (1989)
190 Mercedes (1988)
reggid
Post Sun Dec 18, 2016 1:17 am
not really, some like the look, but quality silcone is expensive at the same time
E30 325is with M20B31
Post Sun Dec 18, 2016 10:34 am
You probably can make a 'better' hose out of silicon than you can out of rubber, but a cheap silicon hose will be inferior to a good rubber hose.
All a coolant hose has to do is retain the coolant at operating temperatures and pressures, which the OEM stuff does perfectly for many years, so why try to reinvent it?
Cloggy Saint
Post Sun Dec 18, 2016 10:35 am
Silicone hoses are shiny, mmmm.
