Hello, can anyone help! i have a light flickering on my E30 dash and have no idea what it is. Only does it now and then and in no pattern. Its not the hand brake light, not the brake warning light but its a round circle with a dotted line around it! anyone help me with what this is?
thanks john
john@espi.net
G reg E30 Dash Board signs
tylerma
brake pad wear mate
are your pads due a change?
if not check the sensors
they are located at rear right and front left
and plug into the pads
also I am gonna move this into the tech section for you
Stolichnya
hi, all brakes are fine, new about 1k ago. its a sign ive not seen B4, i could do with the sad dash picture from a manual saying what stuff does, its got me baffled
Simon
Check the sensors, they probably haven't been fitted properly, and have caught and broken.Stolichnya wrote:hi, all brakes are fine, new about 1k ago. its a sign ive not seen B4, i could do with the sad dash picture from a manual saying what stuff does, its got me baffled
If the wire from the pad sensor is not clipped in place properly it can rub through on the inside of the wheel rim.
If all is well with the pad sensor(s), then there is a common, easily cured fault in the instrument cluster, that causes these symtoms.
Do a forum search for "220 ohm resistor" and my username.
oze30
could you just unplug the sensor?
Simon
The light won't go out, just buy a new one, and fit it properly, they're only a couple of quid!oze30 wrote:could you just unplug the sensor?
I'm sure Brian will tell you how it's the first thing he looks at when buying an E30, isn't it Brian!?
Just one of a number of signs of cowboy activity.Simon wrote:I'm sure Brian will tell you how it's the first thing he looks at when buying an E30, isn't it Brian!?oze30 wrote:could you just unplug the sensor?
Stolichnya
thanks a lot fellas for the tips. am not using the car at the mo as its in for new power steering pump, rack and track rod ends. i bought the car cos i dont want tro use my Supra in winter but thas all i have done as the E30 has had a few probs!
can anyone tell me or sell me bits to enhance performance? or advice? Its an E30 325i Convertible
any help on this would be cool
