Trim removal
Cloggy Saint
Tedswagon
Have you removed all the interior trim? In the 2 door the b trim is bolted on accessible from the inside. From memory the rear quarter windows are fixed in place, not for removal, as for the trim around the rear quarter I guess it's held in place with same strong adhesive!! Just my 2pence.
Tedswagon
http://www.realoem.com/bmw/enUS/showpar ... Id=51_0279
http://www.realoem.com/bmw/enUS/showpar ... Id=51_0411
http://www.realoem.com/bmw/enUS/showpar ... Id=51_0902
Real oem diagram if you've not looked already
Cloggy Saint
The rear quarter trim is held in place with clips. I managed to raise the trim quite a bit but after a certain point it wouldn't come any higher and I didn't want to force it too much. The B trim covers are part of the doors so I don't think removing the interior trim will reveal anything.
Cloggy Saint
Cloggy Saint
Cloggy Saint
Are you using a proper trim removal tool, rather than a screwdriver? This usually makes trim removal easier, with less risk of damage.
If most of the modern cars I have to work on are anything to go by, the trim clips usually require quite a bit of levering before they'll come loose, and you should be prepared for some getting broken; replacements are usually available from the dealers for a relatively small sum.
Cloggy Saint
Don't know if this helps? From the Zone Wiki:
http://www.e30zone.net/e30zonewiki/inde ... im_removal
