Door actuator?
bigade
Post Mon Aug 01, 2016 9:07 am
Morning you lucky people.
Central locking woes ( that old chestnut )
When it locks , three doors lock and then pop up again.
Before I pull door to bits just thought I'd ask on here if anyone has had the same.
I've cleaned connector in the door and tried a different relay.
TIA
Ade
Post Mon Aug 01, 2016 10:31 am
Unlocking again, immediately after locking, indicates that the ECU doesn't think the driver's door is shut.
Check out the driver's door linkage, etc., for lack of lubrication and wear, and the alignment of the locking motor in its slotted mounting holes.
bigade
Post Mon Aug 01, 2016 8:27 pm
Thank you Brian.
When you say motor do you mean the mechanism on the end of the door?
Post Mon Aug 01, 2016 9:12 pm
Locking motor, on all but the last E30s, is mounted on the inner door panel, about half way down, just behind the rear edge of the door card.
bigade
Post Tue Aug 02, 2016 9:51 am
Thanks again Brian, I'll have a look tonight if it's stopped raining.
It would be nice if I didn't have to spend anything for a change!
bigade
Post Wed Aug 03, 2016 7:49 pm
Update.
Lubricanted door lock.
Central locking now works on key;
But when I use the alarm fob (toad alarm) it locks all doors bar drivers door then pops up again on other doors.
Could live with it like that I suppose
Post Wed Aug 03, 2016 7:57 pm
That suggests that the driver's door lock motor isn't being powered.
What happens if you lock with the key, then unlock with the fob?
bigade
Post Wed Aug 03, 2016 8:26 pm
Mmm, central locking stopped working all together again. Multi meter out tomorrow evening
bigade
Post Sat Aug 13, 2016 4:17 pm
Update.
Looks like the ole red/black wire split has sorted it.
Thanks Brian and wiki :D
bigade
Post Mon Aug 29, 2016 12:00 pm
red/blk wire got central locking working, now can't start because of the toad immobiliser
Post Mon Aug 29, 2016 1:50 pm
bigade wrote: now can't start because of the toad immobiliser
That takes about five seconds to deal with!
Do you know what circuits it immobilises? Chances are it breaks the ignition feed to the engine and the starter motor circuit.
Connect a wire from the battery + terminal (or the 'phantom' terminal on the bulkhead, if you have a battery at the rear) to the ignition coil + terminal, and turn the key. If the engine doesn't crank, take the cover off of the diagnostic socket and use a second piece of wire to link pins 11 and 14 to fire the starter motor.
Pin 14 is battery +, so you can use that to link to the ignition coil + if you like.
bigade
Post Mon Aug 29, 2016 6:21 pm
Thanks Brian.
I can get it to run by using both wires, but when I turn it off I can't restart with the key :(
Any thoughts?
Thanks ade
Post Mon Aug 29, 2016 6:30 pm
That confirms that the two circuits immobilised are as I suggested.
I take it you want to remove the immobiliser?
Trace the wiring from it, and you will find two wires connect to two green wires of the E30 loom, and two more that connect to two black/yellow wires (possibly two plain black wires if the original installer didn't have a clue). Connect the two green wire s back together, and the two black/yellow wires back together. Hopefully the cut ends will still reach each other, but if not, you'll have to splice in a short piece to bridge the gap.
bigade
Post Mon Aug 29, 2016 6:57 pm
The alarm was only fitted in march by previous owner, so I'd prefer to just get it working again.
The toad fob locks and arms it ok but doesn't disarm it
e30-unit-soldier
Post Tue Aug 30, 2016 1:05 am
bigade wrote:The alarm was only fitted in march by previous owner, so I'd prefer to just get it working again.
Might be worth going through paperwork and see if it has some warranty.... Sounds like the alarm is faulty.
If it was fitted by a reputable company they should be ok with having a look? Unless it's fitted by a cable tie specialist in which case you might struggle
ChrisHC
E30Zone Contributor
Post Tue Aug 30, 2016 2:51 am
Immobilisers are the work of the Devil, get rid of the bloody thing!
Only yesterday I found yet another bodged bit of wiring caused by immobiliser fitting.
bigade
Post Tue Aug 30, 2016 7:15 pm
Thought i was onto something tonight- tried a different fob and it started!
Ran it for a bit then turned it off, armed it, and now it doesn't want to know with any of the fobs.
I'll ring the place up while i'm sat in it later this week.
fitted by reputable firm
bigade
Post Thu Sep 01, 2016 7:28 pm
Think I'm finally sorted. Power cycled it (disconnected battery) all works as it should.
bigade
Post Thu Sep 01, 2016 10:00 pm
BOLLOX :evil:
bigade
Post Fri Sep 09, 2016 6:32 pm
Sorted, pin pushed back on toad alarm loom :-x
