So firstly it's clear that the black plastic surround/retainer needs to be unscrewed. Once removed, what then?
I'm going to try polishing mine up with a rotary buffer to see if I can save a few shekels....
Prefacelift front fog lamp removal
scottybeemer
take the unit outM6luvva wrote:So firstly it's clear that the black plastic surround/retainer needs to be unscrewed. Once removed, what then?
"you aint gonna take me alive, copper"
Doobit
Might depend on the exact model, but you can remove the fog light lenses without removing the black plastic housing. Only advice is use WD40 on the screws 5 mins before hand to loosen them up. I didn't do this and the screwheads sheared off in the housing which meant I had to take the valence off to fit a new housing.M6luvva wrote:So firstly it's clear that the black plastic surround/retainer needs to be unscrewed. Once removed, what then?
E30 325i Cabriolet Alpinweiß chromie
F12 640d
G11 730d
F12 640d
G11 730d
