Stock Air filter..
JAMZ
Guys,
A previous post made me think about something revering to my stock air-filter for my CAB which i have but arnt using it..
My question is where does the air-flow pipe from the fron of the car fix to?
bearing in mind i have the headlamp washer conversion now on my CAB..
Can someone take a pic and show mw cuz ive always wondered and have had the modified Pipercross ever since i bought the car so im none the wiser
PICS would be very helpfull
cheers
cheers
JAMZ
PLease peeps, 11 views and noone can help?
I only need to know where the intake air pipe to the stock air-filter goes
Pics would be helpfull but arnt necesary
thks again..
thks again..
Intake pipe to stock air filter housing fits into a cut out in the removeable panel that blanks off the back of the headlamps.
JAMZ
Thats what i thought but i havent got any room in the back of the Headlamp covers nor a space where that should go
Well, that's where it goes on every E30 I've ever seen!!! Or does it?JAMZ wrote:Thats what i thought but i havent got any room in the back of the Headlamp covers nor a space where that should go
Got a feeling the air intake was on the right on carb models, so maybe someone has fitted a headlamp back panel from one of these,
Lower right hand quarter should be missing.
JAMZ
yea,seems like thats whats happened...
JAMZ
Im fookin blind then!
It is there,just not in the mind of Jamz obvioulsy
ANYWAY..
As i got the Stock filter here ive pu it back on, dont think it will stay on though TBH but im curious to see if my heatshiedl was even doing anything though if anything i will see a inprovement in MPG.
just like the sound of Cones,av to live with it for the time being.. lol
ANYWAY..
JAMZ
Does anyone use the K&N or outher Panel Filters?
Notice any difference?
The difference will be how quickly your engine wears out.JAMZ wrote:Does anyone use the K&N or outher Panel Filters?
How many standard air filters can you buy for the cost of a K&N?
Stick with the OE filters and change them often.
oguz327
- Captain Armco
Is the K & N really that bad, if so ill be changing back to standard!Brianmoooore wrote:The difference will be how quickly your engine wears out.JAMZ wrote:Does anyone use the K&N or outher Panel Filters?
How much for the original guys?
No, they're not THAT bad, but in the real world don't filter as well as the OE element, and you can buy several OE filters for the price of a K&N.oguz3001 wrote:Is the K & N really that bad, if so ill be changing back to standard!Brianmoooore wrote:The difference will be how quickly your engine wears out.JAMZ wrote:Does anyone use the K&N or outher Panel Filters?
JAMZ
But in both cases you mention nothing of performance.. there must be some gain there even if it is small
Simon
And the M3 doesn't have the cutout either, it takes the feed from the side of the rad.Brianmoooore wrote:Well, that's where it goes on every E30 I've ever seen!!! Or does it?JAMZ wrote:Thats what i thought but i havent got any room in the back of the Headlamp covers nor a space where that should go
Clean OE element will flow every bit as well as a K & N.JAMZ wrote:But in both cases you mention nothing of performance.. there must be some gain there even if it is small
If it didn't then BMW would have fitted a better one.
You need to realise that these cars were designed and built by engineers, not accountants, to a very high standard, not to a price.
BMW is aworld away from bean counter designed rubbish like F**d, Va****ll, etc.
Simon
Couldn't agree more, the BMW air intake system is very well designed, the only restriction being the AFM.Brianmoooore wrote:Clean OE element will flow every bit as well as a K & N.JAMZ wrote:But in both cases you mention nothing of performance.. there must be some gain there even if it is small
Stick with the standard airbox unless you can get a hold of a well designed heat shield that only allows intake from the front of the car.
JAMZ
Well ive done a complete turn around here and im 99% sure ive got better performance now with the stock air box in :S
Might be completley imagining it but ive drove it twice now sicne i changed it yesterdat urban and M-way and im allmost positive which is great.
Miss the sound but thats about it... M-way is when your get the most rewarding gain out of a cone cuz your allmost forcing nice cold air through it as long as its got a good feed but from normal cruising im sure this is better like i said..
TBH i WAS thinking of sticking a upmarket Panel filter in there but not to sure now,maybe just a new OE one like you say as i just used the one that was still in the box,looked fine though but you never no
Simon
When I first had my 325i, I went out and bought a pipercross induction kit for it, thought it was the dogs danglies at the time (this was pre zone!) and I was still quite young! The car was due a service, and because I was servicing it at the dealers, I put the original airbox back on and noticed the difference straight away, suffice to say I never put the induction kit back on, it went on e-bay instead and it went quite nicely on there
