evening guys, am in the middle of changing a cable on a manual sunroof e30.
have dismantelled the mech. at the rearmost end of the cable.
have removed overhead console etc., and have unscrewed every bolt i can see on the winder mechanism but still can't get the cable to disengage/come out- whats the secret final step im missing?
changing sunroof cable
Stubabalu
Stubabalu
biffer
thanks for that,but it doesnt cover what im after.
from what ive read online,the final step to removing a cable is to drop the drive mech.,be it electric or manual,down -then u can pull cable out.
but it seems my manual drive assembly is a one-piece unit-cant see a way of dismantelling further-unless perhaps the centre-cog thing is supposed to come out-it does seem loose.
Stubabalu
I see what you mean try this one there is a trick to it....
http://m-power.lv/files_misc/E30%20m3%2 ... 412240.htm
biffer
bingo -thats it
unscrewing one small screw and the whole thing comes down-had noticed the screw earlier but 'cos it didn't loosen at first attempt i forgot about it.
thanks again!
thanks again!
