1987 325i with cruise and OBC
I've got a two wire plug behind the glove box which i can't remember what it does, had a look on line but none the wiser
It has 2 wires, a solid green and a green with red stripe
Thanks v much
Jim
wiring plug ID help requested.
Immobiliser plug from the OBC and/or another immobiliser.
Plugs into a white socket with two plain green wires, which, if your car runs, must be currently shorted across. Correct shorting link is a plug the same as you have found, fitted with a short loop of green wire.
jimbom30cab
- Tech 1 freak
Brilliant thanks Brian, now you mention it I remember this from last time....i think...memory a bit hazy these days !
On the Cruise loom, same location there is a single blue wire, not sure where this goes either, just looking at the wiring diagrams now
Cheers again
Jim
Cheers again
Jim
jimbom30cab
- Tech 1 freak
Edit: Sorry it's blue with red stripe
Looks like it might be the "auto only relay"
Blue is road speed signal from the green socket on the speedo. Most of the pins are the same signal.
jimbom30cab
- Tech 1 freak
Thanks Brian, i've done that one, actually fitted it to the top
There is another single blue with red (could be brown, sorry colour bind) which is behind the glove box
I'll get a pic, 2 secs.....
jimbom30cab
- Tech 1 freak
BenHar
jimbom30cab
- Tech 1 freak
Do you think it's "E" Ben ?
BenHar
In the top picture the wire is the cut out for automatics. Not required on a manual.
In the bottom picture the earth should have another plug to connect that one to with a brass ring to attach it to the earth point at the other end.
Ben
Ben
jimbom30cab
- Tech 1 freak
Fab, thanks very much Ben.
I don't seem to have the additional brown connection piece so i'll change the plug for a ring connector, should be enough length in it.
Cheers mate
Cheers mate
