Sagging door edge protector
flybmw
Tue Jan 26, 2016 4:42 am
Hello chaps!
Have not been here for ages. Am still happily enjoying my mtech touring 318is. Started to get unhappy about sagging door edge protectors. Haven't found any info on how people restore/fix that rubbery thingy. Photo below:
Anyone found a solution to this problem? Some say that stretching it helps only temporarily. This item can't be replaced with new replacement part. Used replacements will turn into this anytime later anyway...
Thanks!
Tue Jan 26, 2016 9:47 am
Take off the plastic sill trim at the bottom (slide over and back - NOT pull), push the square corner that's adrift hard into place, then slide/push the trim from both directions towards that corner, until everything is firmly in place, with a gap at the bottom.
Cut a piece of surround from an identical second hand one, push it into the gap, fit the fixings to the plastic sill piece and snap it back into place.
jmc330i
Tue Jan 26, 2016 9:55 am
The top section looks too short to reach the corner :?
James
'91 325i Sport
'93 318i touring 16v
BenHar
Tue Jan 26, 2016 10:06 am
jmc330i wrote:The top section looks too short to reach the corner :?
Brianmoooore wrote:, then slide/push the trim from *both* directions towards that corner
Ben
jmc330i
Tue Jan 26, 2016 10:45 am
Ben
:roll:
James
'91 325i Sport
macas
Tue Jan 26, 2016 11:13 am
What material code are those seats??
flybmw
Tue Jan 26, 2016 12:27 pm
macas wrote:What material code are those seats??
Not sure about the code, but the car is 1993 Daytona Violett Design Edition with sport seats interior.
flybmw
Tue Jan 26, 2016 1:33 pm
Brianmoooore wrote:Take off the plastic sill trim at the bottom (slide over and back - NOT pull), push the square corner that's adrift hard into place, then slide/push the trim from both directions towards that corner, until everything is firmly in place, with a gap at the bottom.
Thanks very much.
I was considering this option, but the problem is that opposite the affected corner is another square corner. Doing like you say would create a gap in the left (b puillar) square corner. The top piece has to be stretched somehow. Otherwise, cutting the top part and patching it with used surround cutout won't solve the problem because the patch would be visible and fall down.
Was I clear at all?
