I'm taking the carpet out of my car to clean it and check for any water leaks but I'm stuck on the accelerator pedal how does it come out, I don't wanna try and force it and break it
Thanks in advance
Accelerator pedal removal
DHFiS
There is a metal slot on the floor and the plastic tangs on the bottom of the pedal push onto it.
Benjer182
Ok cheers so does it just pull up ? Or is it a slide to one side ?
blazed
Unclip the top and pull up, you may need someone to press the tangs in so they don't break.
BenHar
If that's not in the wiki it should be.
I'll PM Grrr.
Ben
I'll PM Grrr.
Ben
Benjer182
Cheers lads I sorted it out and the rust I found while I was there
Grrrmachine
- E30 Zone Wiki / Team Member
