Does anyone know.....
TPS
Post Mon Dec 28, 2015 9:39 pm
What tool I need to undo, this Plastic top, from the Oil Filter Housing?
TIA
maxfield
Post Mon Dec 28, 2015 9:52 pm
You can buy caps from eBay or motor factors.
If you measure it and count how many sides you should find that size on eBay.
BenHar
Post Mon Dec 28, 2015 11:06 pm
Strap wrench?
Ben
Post Mon Dec 28, 2015 11:40 pm
BenHar wrote:Strap wrench?
Ben
That's what I use, although I have broken a cap or two with it.
scottybeemer
Post Mon Dec 28, 2015 11:48 pm
"you aint gonna take me alive, copper"
TPS
Post Tue Dec 29, 2015 12:04 am
The only reason I ask, I've used a pair of massive grips in the past, they nearly crushed it. Also, as Brian says a Strap Wrench, could do the same. I wanted to see if anyone, uses anything different to thse items.
jimmyspeed
Post Tue Dec 29, 2015 5:46 am
I think I used a g-clamp on my old m44
ah
Post Tue Dec 29, 2015 9:57 am
Be careful what tool you use because a as I recall it made of plastic.I bought my tool from Halfords.
steve_k
Post Tue Dec 29, 2015 10:12 am
might sound daft, but put a leather belt round it & hold it tight with mole grips & it should come off.
Andyboy
Alpina Colada
Post Tue Dec 29, 2015 11:41 am
Gas pliers and a bit of old rag to avoid marking the plastic.
There oil filter housing gasket on my E36 Touring is leaking - I may fit an earlier type housing with the alloy cap and 13mm bolt whilst I'm at it.
jmc330i
Post Tue Dec 29, 2015 11:57 am
Andyboy wrote: There oil filter housing gasket on my E36 Touring is leaking - I may fit an earlier type housing with the alloy cap and 13mm bolt whilst I'm at it.
I was looking at doing the same on my M44. I was guessing the M40 one would be a bolt on swap?
James
'91 325i Sport
'93 318i touring 16v
Post Tue Dec 29, 2015 12:00 pm
Ive always found the proper tool works wonders :?
As said previously, you can buy one for about £5 from most motor factors
TPS
Post Tue Dec 29, 2015 12:02 pm
Thanks Everyone
Andy - I had a nightmare with that Gasket, one of the 4 bolts holding the housing to the block, decided to shear off, they're very easy to break
TPS
Post Tue Dec 29, 2015 12:05 pm
DanThe wrote:Ive always found the proper tool works wonders :?
Do you know, what is that tool?
TPS
Post Tue Dec 29, 2015 7:46 pm
Thanks Will, thats exactly, what I'm after!
maxfield
Post Tue Dec 29, 2015 8:26 pm
I believe BMW also use a smaller cap as well, 74mm/12 flutes??
Like I said, if you can measure it and count the sides that should give you the size you need
TPS
Post Tue Dec 29, 2015 8:28 pm
I'll be counting & measuring tomorrow
maxfield
Post Tue Dec 29, 2015 9:06 pm
I've got a big box full of the caps, and I still come accross the odd one I don't have.
TPS
Post Tue Dec 29, 2015 10:21 pm
Mines an M42 as well Will, I'll measure it tomorrow. Its strange, most of M40/M42 I've owned have the Metal Housing, & this one has the plastic cap type.
TPS
Post Wed Dec 30, 2015 12:22 pm
It's the 14 flute one
johnl320
Post Wed Dec 30, 2015 2:21 pm
My IS had the plastic type same as yours Phil but was a later engine, if you ever have to do the timing chain, best to check the engine number to see what kit you need, mine didn't have the idler gear which I found out the hard way.
Post Wed Dec 30, 2015 5:47 pm
BMW only gave two sizes of plastic oil filter cap that aren't a hex.
TPS
Post Wed Dec 30, 2015 7:16 pm
Thanks Barry/John
