where are all my lights ?.?
johnono
Post Fri Sep 11, 2015 10:31 pm
Heya. Bit pissed off..
Check control tells me
1) rear position lights fault
2) number plate lights fault.
I have no numberplate lights and the right side rear position light is out.
Also my cluster and geargnob lights are out
And my front headlight position lights are also out?!
All from one day to the next.
Bulbs are checked and changed.
Fuses 21 ,22 and 23 are changed.
Ive tried lookin at the check module in the boot left side , to see if there is anything..
:cry: :(
Boot central locking servo is fine
Entire left rear cluster is fine
What dfuq is the problem please help me !
Post Fri Sep 11, 2015 11:04 pm
Everything that is out runs from fuse 23. There is a common feed wire from the fuse to the lighting switch, but from there on, the circuits divide into two groups. Fuse 23 has 12 volts + direct from the battery on its inner terminal, as have the whole row of fuses from 21 to 28 inclusive.
If you are sure fuse 23 is intact, then there is a fault with the grey/green wire running from the fuse, across behind the dash, to the lighting switch.
johnono
Post Fri Sep 11, 2015 11:34 pm
:) cheers Brian !
Would the rheostat itself cause a problem? The push pull function works no problem.
johnono
Post Fri Sep 11, 2015 11:36 pm
Mines a lefty , so the distance is pretty short :)
If i pull the light switch out, what should i be looking for with the grey/green wire?
Post Fri Sep 11, 2015 11:50 pm
Grey/green wire should have 12 volts + on it all the time.
Nothing to do with the rheostat - that's after the circuits split in the switch.The tail light and front parking light are on one circuit, and the number plate lights and dash lights on the other, but all run from fuse 23.
The reason for the split into two circuits is so that the parking light switch on the indicator stalk can switch on just the essential front and rear light, leaving the number plates and dash off.
johnono
Post Fri Sep 11, 2015 11:56 pm
You are the man :)
Ok , ill measure for the constant 12
If im getting 12 to the switch connector , and its not going further , then a new switch?
johnono
Post Sat Sep 12, 2015 12:11 am
Brian , found this,
Can you confirm?
" PostPosted: Wed Aug 17, 2011 9:46 am Post subject: re Reply with quote
Yes the main light switch on the dash. Before you pull the switch, pull the connector off it and connect the pins....pin 7 to 1 then 5 then 8. if the lights come on, switch is the problem, if not keep looking.
johnono
Post Sat Sep 12, 2015 8:32 am
No power to the fuse on 23
Next step, pull switch and check gy/gn wire connection to switch
Post Sat Sep 12, 2015 9:39 am
johnono wrote:No power to the fuse on 23
To which pin of 23?
johnono
Post Sat Sep 12, 2015 8:09 pm
Sorry Brian , you lost me mate.
Which pin?
But stangest thing happened.. Starded the car today. No problem at all
All worked
Tried the 10 times test.. And it kept working .. So could it be a loose connection behind the switch?
Post Sat Sep 12, 2015 8:29 pm
Fuse 23 has two pins (or blades). The one nearest the middle of the fusebox is 'in' and the one closest to the edge of the fusebox is 'out'.
It would be odd if there's no power at the inner pin, since that is in a line of eight adjacent inner pins which are all soldered to the same piece of copper circuit board track, which is connected directly to the battery, and we know that the other fuses are receiving power.
There's a remote possibility that the fuse holder has cracked away from the copper track (known as a dry joint), but that would fit in with you saying that there was no power at fuse 23, and with the "self repairing" phenomenon.
To check, you'll have to lift up the deck of the fusebox and take a look. The deck is held down by three self tapping screws - one outside, one inside and obvious, and the third also inside, but under a relay. Do not touch the cap bolt you can see.
There are lots of wires connected to the back of the deck, so it needs to be pulled up slowly and carefully - there's just enough spare wire. When you put things back together, ensure that the one plug that connects to the board is pushed fully in place.
johnono
Post Sun Sep 13, 2015 10:32 pm
Cheers lads :)
LucasE30
Post Tue Sep 15, 2015 10:58 pm
Have you tried the rear light check relay situated in the boot (left hand side of a touring)?
