Non starter
vendetta
Post Mon Jun 15, 2015 10:33 am
Help folks my boss at work has given me some money to buy an e30 it's a 325i touring and it won't start serried turning it over starter clicks but nothing else and it got red hot tried to bridge the pins on the diagnostic cap as it said in the wiki still nothing could this be a serious problem or just a duff starter ? Read somewhere about damage to the flywheel possibly help needed quick guys thanx in advance
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Jun 15, 2015 12:05 pm
Put a spanner on the crank shaft nut to confirm the engine turns over by hand.
From there, confirm the engine to body earth strap is in good condition. Try clipping a jumper cable from the block lifting hook (by the oil cap) to the body earth point (right strut tower).
Then put a known good battery on the car, and try starting.
vendetta
Post Mon Jun 15, 2015 1:45 pm
Ok thanx for the advice ile try that tonight
vendetta
Post Sat Jun 20, 2015 4:28 pm
Right earths are all good tried hand cranking and engine won't budge is it possible the starter has jammed something so it won't hand crank advice needed quickly before I have to get new engine
Post Sat Jun 20, 2015 4:46 pm
If it's a manual gearbox, putting it in top gear, holding down the clutch, getting it rolling, then bringing up the clutch is likely to do something. Otherwise, disconnect the battery negative lead, unbolt the starter motor and see if it'll turn over on the crank pulley bolt then.
vendetta
Post Sat Jun 20, 2015 5:00 pm
Thanks for the advice as usual Mr Moore Ile give it a try
vendetta
Post Sat Jun 20, 2015 5:18 pm
I think my clutch might be buggered there's no bite on it just straight down to he floor :x :x
vendetta
Post Sun Jun 21, 2015 11:16 am
Morning took the starter out still won't crank by hand
vendetta
Post Sun Jun 21, 2015 11:51 am
Timing cover taken off belt is in good condition nothing seems wrong in there
