Help with megasquirt 2 and custom loom please
WEEMANDANBRITTON
Wed Apr 15, 2015 8:38 pm
Right basically im going to buy a mega squirt ms2 v3 ecu, i want to make a custom wiring loom for the engine, im going to be running a standard m44b19 to begin with, it will however be fitted with s50b30 throttle boddies and a plenum (custom made ready to go!!) i want to run a maf instead of an afm and want to do a wire tuck!! The m42b18 will go back in eventually with an eaton 45 supercharger from a cooper s mini!! Basically my question is, does anyone have a diagram of the megasquirt plug so i know which wire goes where?? It will be running cop so i will have the extra coil driver, tried googleing but cant find anything!! Any help will be much appreciated!
gromgsxr
Wed Apr 15, 2015 8:44 pm
the main wiring for the ecu will be fairly standard just the options like what pins are being used for the maf input and the extra coil out puts?
gromgsxr
Wed Apr 15, 2015 8:47 pm
NoTurbo
Wed Apr 15, 2015 8:50 pm
it is in the WIKI
http://www.e30zone.net/e30zonewiki/inde ... CU_Pinouts
Have you bought the Megasquirt system yet?
WEEMANDANBRITTON
Cheers :D
