Front brake backing plates
polsta
The backing plates on the front struts /brakes , can they be removed and re fitted with the strut and brakes still in place or whst has to be done ?
Can only be removed if you cut them off or remove the wheel bearing.
BHadley
Mines a facelift and was bolted on with 3 small 10mm bolts .
Remove the disc and you should see the crusty remains...
If not try looking from the back of the strut assembly
RB2
You still need to remove the wheel bearing unless yours were very corroded
BHadley
Thinking it about it they where, must have dislodged a bit and the rest pulled through!
