Boot lock removal
Igotwood
Post Sun Sep 14, 2014 2:46 pm
Hi, trying to remove the rear boot lock, I've undone the bolts but can't seem to pull the externally black part off, any advice greatly appreciated, gonna try and upload a picture to help
Igotwood
Post Sun Sep 14, 2014 3:01 pm
bigbird76
Post Sun Sep 14, 2014 4:06 pm
Have you unbolted the solernoid from the framework, 2 7-8mm self tapper bolts? and unhook the little bar that joins to the lock?
Leigh
Igotwood
Post Sun Sep 14, 2014 4:30 pm
Yep. Solenoid is removed, inclusive of arm. When I pull the cylinder from outside the boot, it won't pull away from the rear panel, is it just a case of pull harder ?
bigbird76
Post Mon Sep 15, 2014 9:09 pm
Cannot remember fully since i did my lock.
Just found this if it is any help?
http://www.e30performance.info/viewtopi ... =35&t=1590
Leigh
