Post
Sat Jan 07, 2006 1:43 pm
ali cum salam (it is all phonetic anyway!)
not sure which is easier, probably to change the whole hub would be easy and to change the whole arm would also be easy (if you have the right tools and a place to do it!)
it is probably more work to remove the hub when compared to the whole arm so i would imagine thats why the scrap man wants to do that, its easier for him to remove.
if you are changing the arm then best bet would be to replace the bushes too, that would then really mean you should change the passenger side too, so that would be some work,
if its cheap buy the whole assembly, strip it down and decide!
good luck
and
ma-salama
mrlee
