engine cutting out 318is help please
page
Post Mon Sep 08, 2014 12:36 pm
o.k so had the fuel pump replaced in my 318is was driving tidy up until yesterday when it cut out on me twice, once waiting at traffic lights, and 2nd time was when pulling off(no i didn't stall it) it also went to die on me when on the move but i dropped the box and kept the revs up high until i got home.
Also sometimes it's not idleing right
DaveMcleod88
Post Mon Sep 08, 2014 1:22 pm
did it just turn off dead or slowly die to a stop? plugs on top of the fuel pump might be loose this happened to mine
page
Post Mon Sep 08, 2014 2:38 pm
just turned off dead, thanks for replying :D
A18RPF
Post Mon Sep 08, 2014 9:13 pm
Does the problem persist with the tank filled with petrol ?
TheDutch
Post Mon Sep 08, 2014 10:36 pm
page wrote:had the fuel pump replaced
With a new one?
Captain_Birdseye
Post Tue Sep 09, 2014 5:25 pm
hmm... do e30s have an Idle Control Valve? If not then it could still be a hole in an air pipe? That would make it cut out unless revs where high and effect the idle. If I'm wrong about the hole it still won't take much time to check.
page
Post Tue Sep 09, 2014 7:22 pm
hiya thanks everyone, yes fuel pump is definately new.i filled the tank up when i picked her up from the garage, but it cut out on 1/2 a tank, hasn't happend since the two times i mentioned above. have to add i'm not a mechanic, and you know whet bulls.hit garages feed females sooo.... in all honesty i don't think there was anything wrong with the immobilizer, i ended up paying £350 for all the work, petrol pump and an auto electrician to sort out immobilizer, skanked but what can i do :o:
BHadley
Post Tue Sep 09, 2014 7:47 pm
Fuel filter changed recently? Or with the pump?
Cured my 318i a few years back when I had a lack of power then a big serge of it!
Build up of crud at the bottom of the tank plus running the fuel very low could cause a blockage or low flow resulting in running problems...
You Could check the air intake pipes big and small on the passenger side of the engine bay with brake cleaner, if there's a leak the engine revs rise, think there is something about it in Zone wiki.......
page
Post Wed Sep 10, 2014 2:24 pm
slideout318i20 wrote:Fuel filter changed recently? Or with the pump?
thanks will get that checked :D appreciate ur help peeps!
Post Wed Sep 10, 2014 2:54 pm
Check the connection to the fuel pump; perhaps the garage didn't fit it securely enough...
page
Post Wed Sep 10, 2014 8:53 pm
will do, it wouldn't suprise me, thanks again everyone for all of your advice, hasn't done it again, but i'm paranoid about it now so needs to be sorted
Post Wed Sep 10, 2014 11:10 pm
Also check the fuel pump relay; try swapping it with a known good or new one.
