318is vacuum pipes @ MAF?
samuraibaz
Post Thu Aug 14, 2014 5:34 pm
I am currently running various pipes using both vacuum entry points just after MAF on underside rubber boot is that correct? My other rubber boot from another 318is has 1 of them blanked off???
mcspike
Post Thu Aug 14, 2014 6:42 pm
I think there were quite a few different setups for the M42 vacuum and cooling pipes. Googling info on the throttle body heater delete and 'mess under the intake' should help you. M42 club is pretty useful.
http://www.m42club.com/forum/index.php?topic=2742.315
http://www.m42club.com/forum/index.php?topic=4258.15
Ryan
Post Thu Aug 14, 2014 10:30 pm
You can have a mass cull of coolant and air pipes around the inlet side of a M42.
The small coolant pipes can be replaced by a single bypass pipe from one end to the other, or both end connections just blanked off, and all that need remain of the air pipes is a simple pipe from the cam box breather to one of the connections on the big air pipe, a simple pipe from the other connection in the big pipe to the idle valve, plus the pipe to the brake servo valve.
Can anyone suggest a reason for those siamesed pipes that BMW fitted?
samuraibaz
Post Fri Aug 15, 2014 4:10 pm
cheers guys liking the minimal pipes option sounds too easy & gets rid of loads seems strange BMW didnt do it that way???
DHFiS
Post Fri Aug 15, 2014 8:41 pm
samuraibaz
Post Sat Aug 16, 2014 4:03 pm
amazing links guys all stripped down & done even made original coolant pipe work (leaks pending lol) & looks so much cleaner around inlet plus lost the rough idle
