As you can see the plastic sliders on the gutter don't slide on both sides in the "rails" , right side is in limits while left side sits on top. How should they sit and slide on those black rails?
I'm also having problems with gluing the upholstery fabric on top of the old roof liner fabric as i saw it was written in the wiki. It just gets too thick for the liner frame to slide in the rails when the sunroof closes and it takes a fair amount of force to slide it ( i tried it with my hand without the roof installed to check operation )
i also put a bit of grease on that side but didn't made much difference.
If anybody did it and has some experiences to share please do it... i'm so fed up with the thing .
I also have pics of the fabric glued on the liner and will post them bellow to show where it is too thick for it to slide normally.
the red arrow is where it has resistance when sliding
The front left and right sides of the liner
The whole liner fabric glued on top
i would really appreciate your help.... i really don't know how to make it to slide and work properly and rain is about to fall and ruin my rest of the upholstered liner and inside of the car.
Many thanks,
