so after the engine has idled for about 3-5 minutes there´s a fairly noticable dripping , off the engine carrier.
The hosing to the expansion bottle / thermostat / cooler are dry
The hosing to the matrix is dry
Im thinking Ãt must be off the coolant pipe along the head ?
the one you can just see between the strut tower and coil
After 10 minutes the leaking stops.
And doesnt come back even after driving for over an hour.
But if it alowed to cool to cold, then the leaking begins again on start up after 3-5 minutes..
No abnormal pressure in expansion bottle
oil and water look fine
ffs
