rear subframe
Jamie8GTi
Post Wed Feb 19, 2014 7:04 pm
not really to technical.. i'm having trouble dropping the rear subframe, removed the trailing arms so its just the subframe left, removed the bolts and the cups that bolt to the sills but cannot get the bloody thing to budge.
is there any trick to it or is it just a brute force and patience job.
removed one previously from a donor car which I seem to remember was a coont..
Almost brought the shell down on me last night and don't really fancy dying over a rusty subframe haha
if not I might even cut it up to remove it
cheers
PG325
Post Wed Feb 19, 2014 7:10 pm
What about the bolts that run from the car through the subframe bushes, I believe these can seize together, have you hit the bolts into the car?
Jamie8GTi
Post Wed Feb 19, 2014 7:14 pm
The ones with the splined heads? yes knocked them through and took them out, I posted this because I remember the bushes have the aluminium blocks running through them and it looks like theres some sort of flange on the chassis they locate into but can't really tell as its all been undersealed
and1_e30
Post Wed Feb 19, 2014 7:25 pm
i had that trouble i got some treaded bar and shoved it in there and went like mad moving it , and it came off :)
ross2009
Post Wed Feb 19, 2014 7:45 pm
they will just be stuck if youve undone the main bolt and the cup bolts thats all thats holding it it will have to be abit of brute force to get it out its them ali bits in the middle that will be holding it
Turbo M20
v8 project 6.0 twin turbo
jimmyspeed
Post Wed Feb 19, 2014 7:53 pm
wd40 the aluminium pieces, from the top won't hurt, but also underneath above the steel rim (looks like a hat )
then stick suitably sized bar or the old bolt up into the bush from below and wiggle it - helped get mine of a few weeks back
Jamie8GTi
Post Fri Feb 21, 2014 5:50 pm
thanks guys its coming off this weekend whether it likes it or not!!
