Bmw e30 wipers
ibzy
Post Mon Feb 10, 2014 9:16 pm
Have a bmw e30 and when i put the wiper stick down the wipers are not continuous and stop then the stick goes back up what solution do i have to fix this so the wipers keep running till i put the stick back up
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Feb 10, 2014 9:49 pm
Have you tried pushing the stick up instead of down?
trevski
Post Mon Feb 10, 2014 10:05 pm
ibzy wrote:Have a bmw e30 and when i put the wiper stick down the wipers are not continuous and stop then the stick goes back up what solution do i have to fix this so the wipers keep running till i put the stick back up
This sounds like your wiper motor needs either taking apart cleaning and regressing or get a good working replacement. Symptoms are usually the wipers not not parking when the stalk is pushed down or not parking when on interval wipe.
ibzy
Post Mon Feb 10, 2014 10:29 pm
Grrrmachine wrote:Have you tried pushing the stick up instead of down?
No havent tried that will check that tmorrow
ibzy
Post Mon Feb 10, 2014 10:30 pm
How much are replacment ones roughly
Cloggy Saint
Post Mon Feb 10, 2014 10:55 pm
Sooo, how long have you been driving with the stalk held down in order to keep the wipers going?
Laith
Post Mon Feb 10, 2014 11:01 pm
ibzy
Post Mon Feb 10, 2014 11:04 pm
I havent just started a project
Post Mon Feb 10, 2014 11:51 pm
I'd definitely try this before pulling things apart!
Fred555
Post Thu Feb 13, 2014 12:01 am
Seriously are you for real???? If so when my wipers packed up I just had a traffic light squeegee merchant ride on the bonnet (held down with duct tape) and instead of using the wiper control stalk just yelled commands through the window - got through three MOT's like that......... :mad:
All you need to fix anything is grim determination – that and belief.
harry_p
Post Thu Feb 13, 2014 1:02 am
Pressing the stick down is to give one wipe of the screen.
Press it up one and it will run in intermittent (every few seconds)
Press it up another notch and it will run continuously at normal speed.
Press it up another notch and it will run continuous at high speed.
Pull it towards you and it will wash the screen.
Have you discovered that twisting the knob which turns the headlights on adjusts the brightness of the dashboard lights? :wink:
cheers,
harry
