drum brakes to disc's.
spiderman
Post Sat Jan 25, 2014 1:11 pm
I want to convert my pre facelift e30 320i from drum brakes to discs. Do I have to change the complete arm or just brake assembly. If so will touring arms, or cabby arms fit, or cabby arms(one of each in local scrap yard), or go gor 325 setup.thsnks in advance for advice.
wullie325i
CAUTION - unreliable trader!
Post Sat Jan 25, 2014 1:16 pm
full 325i rear beam with all the gubbins is what you need
Post Sat Jan 25, 2014 1:32 pm
AFAIK, all the Tourings had the 325i rear discs as standard. :wink:
Jim320i
E30 Zone News / COTM Team
Post Sat Jan 25, 2014 2:06 pm
Tourings and convertibles both use disc on the rear which is exactly the same as any other rear disc E30. The only difference is the tourings have larger calipers so if you have the choice of a set with calipers, go with the touring for sure.
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Jan 25, 2014 2:44 pm
Everything, including the parts list, is outlined here:
http://www.e30zone.net/e30zonewiki/inde ... conversion
