retro Fitting heated seat kit
sweep
As above from fitting the elements to the wiring in.
dusty23
There was a guide linked or on here at some point, I think ratch linked it or mentioned it
1988 M3 lachs silver S50B32
1989 325i sport delphin grey
1993 316i lux touring lazur blue
Pete, you must be VERY bored !
Loom and switches are the easy bit. Loom plugs into the socket behind the glove box and routes down to seats.
Seats require total strip down!
bmwe30mtech
You can actually fit into the seats quite easily. Just remove the seat back from the base, and then unpin the squabs at either end. Then sticky tape each length of heating element onto the end of a flexible 30cm ruler and slide them down the inside of the squab, between the two layers of fabric. Takes about 3 hours to do both seats carefully.
Saloon seat yes, cabrio or M3 seat no.bmwe30mtech wrote:You can actually fit into the seats quite easily. Just remove the seat back from the base, and then unpin the squabs at either end. Then sticky tape each length of heating element onto the end of a flexible 30cm ruler and slide them down the inside of the squab, between the two layers of fabric. Takes about 3 hours to do both seats carefully.
sweep
I have sportz seats...very busy at minute pete moving garage..
Jozi
I'd love to know how easy or hard it is to do this with Recaro Ls' and if it wasn't an option are there after market kits that will fit?
Cloggy Saint
