diagnostic port
alfa12177
hi anyone got a picture of the diagnostic port with numbers visible having trouble reading the numbers on mine .many thanks chris
JF008
Does it mean you can't get a rolling road remap as there is no live data available?
You can't remap it via the diagnostic port; the EPROM chip has to be removed from the ECU and blanked, then re-programmed.
(Or just swap the chip for a pre-programmed one).
Modern cars have flash-programmable ECUs that can be reprogrammed via the diagnostic port.
