I've sourced a decent price on a set of e36 Front Wishbones. The seller claims they are compatible but doesn't go into any detail.
Im running a 1990 e30 316i coupe and its failed MOT on front wishbone ball joints.
Are the e36 and e30 wishbones the same?
Cheers guys
Are e30 and e36 front suspension wishbones the same?
E30 wishbones are used as an upgrade to E36s. Would be a downgrade fitting E36 ones to an E30.
£57 each for Lemforder from carparts4less with £15 off if you spend more than £100
That's complete new arms, BTW, not just willnz's ball joints, which are considerably cheaper, but more work to fit.capri_rob wrote:£57 each for Lemforder from carparts4less with £15 off if you spend more than £100
