GAZ GHA Coilovers - advice needed
Arsen_Design
Post Thu Oct 24, 2013 12:06 pm
hey guys,
im looking at getting the gaz gha coilovers for my saloon, i was expecting it to be a fairly straight forward job.. until i have gone to the gazcoilovers site which states:
'In all cases we will need you cars front struts as the stub axle forms an integral part of the build process.'
now that makes its a bit of an issue. i dont really want to have to send my struts anywhere.
did anyone fit gaz gha on their car and did you send your struts anywhere to do it?
i could also just pick the gaz gha from any shop and NONE of them asks for your struts...
honestly confused by that... :roll:
cheers,
michal
andrew_baran
Post Fri Oct 25, 2013 8:52 am
Due to the design, all PROPER e30 coilovers require them to be built on an original strut stub axle.
If you can find any "off the shelf" ones then they more than likely will be doing a trade-in type of thing, where you fit your coilovers, then send your original front struts to them!
harry_p
Post Fri Oct 25, 2013 9:52 am
Buy a spare pair of struts and send them off.
It's how e30 coilovers are. Noone makes the stub axel part from scratch, they either source the struts themselves and add that to the cost, work on an exchange basis, supply a kit that needs to be welded, or are a hideous bodge job setup like the cheap jom / hottuning setups which use an adjustable platform balanced on the old spring perch.
cheers,
harry
Arsen_Design
Post Fri Oct 25, 2013 1:08 pm
@harry_p - where could I pick up a pair of struts? Any online shop you would recommend?
Rich320I
Post Fri Oct 25, 2013 2:02 pm
Arsen_Design wrote:@harry_p - where could I pick up a pair of struts? Any online shop you would recommend?
on here a wanted add is your best bet, i think magpie is breaking a touring which will have the 51mm struts if thats what your after
ross2009
Post Fri Oct 25, 2013 8:56 pm
just get a pair of ebay or on here and send them off to them simples !!
Turbo M20
v8 project 6.0 twin turbo
