885 325i cylinder head wanted
Docawf
Post Tue Sep 24, 2013 12:39 pm
Hi
I need an 885 head casting for my 1990 325i touring. I'd be grateful for any advise re how to get one. I have seen them on ebay, and from breakers, and on this forum. How can I be as sure as possible that the one I get is a good one? My cylinder head is cracked along the bottom of the cam shaft seating, I believe. My mechanic says the other parts, valves etc are good, and he can refit them into the new head.
anothere21323i
Post Tue Sep 24, 2013 12:46 pm
Hi there,
I have a good one that comes with a crack test certificate. I bought it to replace the head in my 325i but fitted an M52 instead.
PM me if you're interested.
Docawf
Post Tue Sep 24, 2013 1:17 pm
I did pm you, but not sure if I sent it correctly, so I'm posting my message here as well.
Hi
How much do you want for the head? Is it the casting or the head with all the bits fitted? What was the mileage? Anything else I need to know!?
Thank you
Andrew
anothere21323i
Post Wed Sep 25, 2013 9:40 pm
Replied :D
