Washer fluid light
Justin325i
The washer fluid light is showing on the check panel, tank was full but emptied it out cleaned the 'gunk' and re-filled with ready to use screen wash but light is still showing, can anyone advise.
'93 E30 325i Calypso Cab
BenHar
washer AND fluid AND light
Put that in the search function.
Ben
Ben
hennared323i
Was the sensor put back in upside down?
mng786
Mine was doing the same thing.
Took the sensor out and it was covered in gunk.
So i cleaned it and put it back in.
Still the same! Then i noticed it was upside down.
Turned it around and BINGO...... Hasnt come back on
Since.
The outside of the sensor is round on 1 side and flat
On the other.
The flat side needs to be closest to the drivers side
Wing. (If that makes sense)
Since.
On the other.
Justin325i
The sensor in the tank was moving freely and outside the tank the pins are facing up so the flat side is facing towards the drivers' wing.
Justin325i
Found a break in the wiring
