Replaced my throttle body, along with the tps, with a spare one.
The original developed a coolant leak.
Now the car seems to be running a little too rich...
Car was running perfectly before the change.
Any ideas?
1990 325i
Running rich after throttle body change
jimbom30cab
- Tech 1 freak
is the TPS set up perfectly, they are quite fiddly to get right
if so then i'd check the TPS with your multimeter
oomz1975
jimbom30cab
- Tech 1 freak
I've found it needs to be exactly right between just before the click and not opening the butterfly, it's a very fine adjustment.
Worth also checking it's not full of oil and give it clean with something like carb cleaner etc
oomz1975
Thanks....jimbom30cab wrote:I've found it needs to be exactly right between just before the click and not opening the butterfly, it's a very fine adjustment.
I'm sure it's just adjustment, I had cleaned it prior to fitting.
oomz1975
