over heating cab
ash123
Post Sat Dec 10, 2005 2:04 pm
this morning my 320i auto started over heating,i was getting water running out of the lower front wing/passenger footwell area i thought it was the heater matrix so i took the 2 pipes off and conected them togetherbut its still the same any one got any ideas
mrLEE30
Post Sun Dec 11, 2005 6:24 am
did you bleed the system after you have cancelled the heater matrix?
what pipies did you connect together?
is it still leaking?
ash123
Post Sun Dec 11, 2005 8:32 am
i conected the 2 pipes going through the bulkhead,it seams to have stoped leaking now and no i have not bleed it beacase i couldnt find a bleed screw on the rad how else can i blead it
SHAZ325iSPORT
Post Sun Dec 11, 2005 8:46 am
you can bleed it by opening the nut on the thermostat housing placed in the middle of the radiator,its got 2 hoses connected to it,i think its a 8ml bolt.
ash123
Post Sun Dec 11, 2005 9:46 am
right ive had another look at it and it seems when the engine is running 2 out of the 3 pipes on the thermostat housing are getting warm the one which goes to the bottom of the radiater remains cold could it be the therostat
