lighter not working no sat nav
daneilhussain
hi ya guys my lighter plug in not working as i was looking on driving the e30 to london but sat nav wouldnt power up once i pluged it in. SO i got lost lol any ideas
beemerbird
Buy a map?
jmc330i
Got leccy windows? Do they work with the doors open and ignition off?
If not, check fuse 28.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
jmc330i
beemerbird wrote:Buy a map?
James
'91 325i Sport
'91 325i Sport
daneilhussain
buy a map come on lool had a look at fuse 28 seems ok replaced it anyways still no luck any ideas?
bmw9818
has the pin in your sat nav charger fallen out? its surprising how many geniuses come into work getting arsey that their sat nav is broken, yet the pin on the tip has fallen out!
zd3bx
What fuse did you put in there? Should be 30A.
daneilhussain
sat nav fine mate as it powers up in my other 30 yes mate ive fitted a new 30a still no luck
Topblag
Check the connection to the fag lighter, ashtray out and you should be able to see.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
billgatese30
Thread moved from E30 Chat to E30 Technical Help. Your thread should receive the correct responses when posted in the correct forum area. Please try and think about the subject of your thread before you post and consider if you are posting in the correct section.
Please read the linked announcement below.
http://www.e30zone.net/modules.php?name ... c&t=186034
Regards,
E30Zone Team.
Regards,
E30Zone Team.
