ABS light
herman
Post Fri Dec 09, 2005 11:11 pm
ABS light was on, went to a garage with, so they said the gear. They said the rear wheel sensor needed replacing, did this Ԛ£70 for the part. The light still on. Rang the garage back they said it needed re-setting and only a BMW garage could do this. Any ideas how I can reset light. Need a MOT now.
Post Fri Dec 09, 2005 11:25 pm
The only "gear" needed to find a dud ABS sensor is a Ԛ£5 multimeter.
ABS light goes off as soon as it's happy, nothing to reset.
Find a new garage.
bigkev
Post Fri Dec 09, 2005 11:32 pm
sounds great but whats the values of resistance for the sensors please
cheers :)
Post Fri Dec 09, 2005 11:36 pm
2nd time tonight I've posted this. About 1000 ohms each.
herman
Post Sat Dec 10, 2005 12:33 am
Thanks for the advice
herman
Post Sun Dec 11, 2005 11:25 am
The sensors are ok now light still on, could this mean a new control unit or does it go to OBC
Post Sun Dec 11, 2005 11:46 am
herman wrote:The sensors are ok now light still on, could this mean a new control unit or does it go to OBC
The ABS light come on with the ignition and stay on after the engine starts without the car moving?
If you take the plastic cover off the ABS unit (behind LH headlamp), there are a couple of relays there. I've never had a faulty one, but I've read that one of these is the usual culprit.
herman
Post Sun Dec 11, 2005 2:23 pm
Replaced the two relays, no joy, must be a wiring problem. Any other ideas.
dasparkybad
Post Sun Dec 11, 2005 3:49 pm
there is another relay behind glovebox shoould be a silver one had to change this on my own car because abs light stayed on all the time
herman
Post Sun Dec 11, 2005 7:24 pm
Is this behind the glovebox in the car or on the bulkhead, engine bay?
