Replacement sterring wheel horn not working?
Podge72
Post Fri May 31, 2013 4:48 pm
OK...old wheel off, new wheel on...only problem is horn now not working.
The old tech 2 had two wires brown (presumably earth) and black. New steering boss only has one wire (black) so have connected this to + terminal (i.e same as tech 2 connection) and nothing. Have tried the other terminal too.
I did initally tighten new steering wheel/boss which made the horn go off constantly so slackened off slightly which made it stop, if that has any bearing on anything.
votivequagmire
Post Fri May 31, 2013 4:59 pm
It sounds like you've connected it directly to the earth somehow. Disconnect the cable and tighten steering wheel nut again, if it still goes off still then there may be a compatibilty issue . If you have a continuity checker then ensure the horns aren't stuck on in any way.
'88 325i M20, could've done with a sunroof.
