Hi MOT time last time had advisory on rusty brake lines so assuming will fail on this. how easy is it to replace them .also
should I go for copper pipe and flaring tool , or get steel pipes from BMW (understand they are cut to length will the fitting already on), which pipe is better steel or copper is this a diy or a pita to do . thanks
replacing brake lines
tom325sport
Motorhole
If you do your own, don't use copper as it hardens and becomes brittle with vibration. Kunifer is the material to use, copper-nickel alloy. Most motor factors/online shops/ebay stock it
tom325sport
This.Motorhole wrote:If you do your own, don't use copper as it hardens and becomes brittle with vibration. Kunifer is the material to use, copper-nickel alloy. Most motor factors/online shops/ebay stock it
