This is one annoying problem that I cant get to the bottom of- its happened on both cars so unless I'm really unlucky, someone else must have experience of it...
The wipers/screenwash come on on their own. On the bronzit it does happen when driving over a bump, suggesting its an earth type or short type fault.
The malachite one is stranger as it will activate when standing still, ignition on, engine off.
I've swapped relays, tightened earths in steering column but to no avail.
What should I do next? At the mo the only fix is remove the relay and pray for no rain.
