hi there guys may car is making a lot of noise from the rear when i pull away quick its not wheel spinning its just trampping the axle
didnt used to do it only got worse the past few days
whats the most common prob???
what causes axel tramp
Grrrmachine
- E30 Zone Wiki / Team Member
If you're getting clunks from the rear it's most likely the subframe bushes - most are shagged on these cars by now.
BenHar
Could be the shock absorber top mounts.
By the way, axle tramp normally refers to solid rear axles mounted on cart springs that move sideways and twist unless very well tied down. Like on Ford Crapis (without the well tied down bit).
The e30 rear suspension is much more sophisticated than that.
Ben
Ben
Could also be worn out shock absorbers (dampers); try bouncing each corner of the back of the car up and down - it should settle on the first bounce rebound.
skooshy
ok guys ill give that a shot
one of my mates says maybe my half shafts are worn???
not sure how they can wear but any thoughts into that???
They have universal (CV) joints that can wear out.
http://www.e30zone.net/e30zonewiki/inde ... ut_Flanges
Duke137
Never knew that.BenHar wrote:Could be the shock absorber top mounts.
Ben
Having watched some of the E30's (and other BMW's) at Santa Pod last year there was plenty of Axle tramping and fooked rear subframe bushes! So whether it is the correct terminology or not it can definately happen on quite a visually staggering scale
Andyboy's Restoration Bible has this to say on the subject:
http://books.google.co.uk/books?id=v7V5 ... CFQQ6AEwBA
Also, check that the rear anti-roll bar linkages are intact.
BenHar
http://www.etyres.co.uk/glossary-tyre-t ... axle-trampDuke137 wrote:Never knew that.BenHar wrote:Could be the shock absorber top mounts.
Ben
Ben
harry_p
Not true though, it can happen on any car in the right conditions at a certain resonant frequency.
Most common in old cars with leaf springs as the axel would try and wind itself around the springs, the tyre would slip, releasing tension in the spring, make the wheel hop and the process repeat on landing.
Certainly knackered bushes, mounts and dampers can make it worse, but its not unknown even on brand new cars.
And e30 rear suspension is far from sophisticated!
cheers,
harry
harry
"what causes axel tramp"
This:
[youtube][/youtube]
This:
[youtube][/youtube]
On an E30 I feel that it is more to do with the angle of the trailing arm and torque on launching, but yes shagged dampers/bushes/springs will only make it worse
I am an axle tramp victim
